Camber issue on stock suspension
    92 LX. Auto. I had to replace the right front axle/CV today. I had the car aligned while it was there and they said that the camber on the right front is off.
    I am a little confused because the car is stock.
    What would cause the camber to be out of alignment? Bad Ball joint? Bad Strut?
    I could buy a ball joint camber kit but want to know why before I just repair it.
    Any help would be great! Thanks.
    92 Lx Accord
    92 DA9 Integra (daily driver)
    Sagging springs. Look at your car at an even road.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      I agree on coil springs comment. In addition, bad joints, improper install of upper control arms, or front suspension/unibody damage unknown to you. If no inspection reveals failed parts in front and still not aligned, you may just have to buy an aftermarket camber kit to correct to prolong tire life.
        If the car has been in even a small wreck (even what seems like a nudge), that could throw the camber off a bit.
          Bad struts as well? They are the original struts on the car. We are the second owners but have never changed them. It is the wifes daily driver and is all stock.
          In order to prolong the life of the tires I bought, I should possible look into springsd and/or struts?
          Thanks.
          92 Lx Accord
            lakeside as in east county? if it is and you want/need any help lemme know
