Car stalls when coming to a stop.
    I have a problem with my 92 Accord LX. When I come to a stop the car will stall, this only happens when I have 1/4 tank of gas or less.
    I was initially having a problem similar to this one Engine Dies While Driving. Help diagnose this.
    After changing:
    1. Fuel pump
    2. Fuel Filter
    3. Fuel pressure regulator
    4. Ignition Control Module (Finally did the trick)
    After finally changing the Ignition control module the car is now running correctly except for when the gas gauge gets below a 1/4. This usually only happens when I am coming to a stop but it also happens if I go into a right hand corner to hard and sometimes when I am on a hill at a light. But under any of the above conditions it doesn't every time. It seems to happen more if the A/C or air is on, so I was thinking maybe a problem with power. I just can't figure out why it would only happen when the gas is low and not all the time.
    I have changed almost everything that I can in the fuel system.
    Anyone have any ideas?
    Try cleaning your IACV and check fuel pressure.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      maybe your gas gauge is wrong.
      My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
      New people click here
        Your not blowing any fuses are you?
          check your IACV...And also try adjusting your idol set screw look in the beginner topics there is an article there on setting your idol
            idle*
            峠 で ドリフト を して 下さい。
            steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
              Thanks for the suggestions. I will try cleaning my IACV and checking the fuel pressure.
              I have already adjusted the idle it was running about 750 rpm now I have it at about 900.
              Thought about the gas gauge being wrong. Maybe when we put the fuel level sensor/float back in we bent something or put it on backwards, but when I fill the tank it shows as full on the gauge and doesn't even barely go above the full line.
              Thanks again for the suggestions and will try everything and see how it goes.
                car stall
                These are nice tips but first I'll focus on gas gauge. Then I'll try cleaning the fuel pressure and see what will happen.
                __________________________________________________ ______________
                us car part.com
                  whats the condition of your o2?
                  (129)Transactions and counting
                    I had a problem similar to this, my O2 sensor was corroded and it was causing me to stall at lights and low RPM's. But it does sound like your not getting the fuel from the tank. Especially since you turn a corner the fuel sloshes to one side of the tank and you stall...hmmmm......
