F20A5 Turbo 250 -300 hp? Possible?
    Hi, I'm new here, and i try to find some information about F20A5( stock 137 hp) engine but i don't see any information about this engine. I would like to add my Acc. turbo to have about 250-300 hp. Stock engine will not blow? Sorry for my english.
    P.S. I'm from europe - Poland
    Any answer will be good to hear.
    You have a 9.5:1 compression ratio, which is fairly high in comparison to the F22A's 8.8:1. Still something you can work with, but you'll have less room for error when tuning.
    250whp has been done quite a few times on an otherwise stock F22A on here, so I'm sure the F20A5 is just as capable. Just be sure to get a properly sized turbo, injectors, and intercooler, as well as a quality wastegate. Then be sure you get the ECU tuned carefully.
    Most stock-block turbo motors DO blow up eventually. The ringlands are the first thing to give out. I'm quite sure you'll be able to pull off 250whp. 300whp might not last very long.
      This information is for me very valuable. My mechanic dont have experience with that kind of motor, he work mostly with Civic's,. Cylinder head will be upper. Turbo will be GT28RS, jdm intercooler, ECU - P28 with chrome, fuel pump - walbro 255, street clutch, exhaust 3" from engine to muffler, injectors we will try in few versions.
      If any have any suggestions,tell me.
