Front suspension renew
    ok weird title but anyways i received my front suspension yesterday (UCA, LCA, ball joints and all that) and i was wondering if i could get a freaking step by step (spoon-fed) DIY on how to freaking replace every part there, and mayb. even a vid. lol, i have a couple tools, no air gun or shit like that, so TIA guys lol
    if nothing is rusted then its pretty simple. ALl you do is unbolt both ball joints and the knuckle. Take off the axle nut and then the knuckle is off the car. Remove the snap ring and hammer the old balljoint out. Install the new one and your good to go. For the upper balljoint all you do is replace the whole control arm. Its only held in by 2 bolts under the hood.
      Start by spraying everything down with PB Blaster. Do that now while you are waiting for other replies.
      Then do it again in the morning and start working on loosening any stuck nuts/bolts.
      You'll need a big pipe (4-6 feet) that fits over your breaker bar and you'll want to rent a tool from the autoparts store to pop the ball joint out and a press to put it in.
      90 Accord Ex, F22A4. Slight fire damage.
