94 f22 from an ex accord
    like the title says would the f22 from an ex be a exact swap or is there other work
    help anyone
      F22 what?....theres our F22Ax thats also found in the prelude and a F22b1 theres a DOHC and SOHC?...
      .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
        You don't need to bump your thread every 40 minutes... That's the best way to get it deleted.
        He said it's from a 94 EX, which, assuming it's a USDM car in question, makes it the F22B1. A few things need to be done. Mounting, wiring, etc... There is a full writeup by DarkCloud in the swaps section. Look it up.
        However, the F22B1 is a complete turd when it comes to performance. It's one of the worst F22 engines ever. Restrictive ports, lousy valve angle, heavy VTEC valvetrain (which only has "vtec" on the intake valves...)
        If you want reliability and fuel economy, it's great. If you want a performance upgrade... the F22A you have now is a much better choice.
          looking into H23 wouldnt hurt if your looking for a swap a H23 is your bet..prize range is less than a H22....wouldnt be so hard...but why try to swap???...
          the F22A has plenty of potential to go around and to show...i say why fix something that int broken.....so if ur F22a is running like a champ think of builting it u'll be surprise what can peak out.....
            well thanks too you both ill make sure not too bump my threads
            plus im gettin the engine for cheap i just wanted to kno if its worth 150 bucks lol
              well how many miles does it have on it if it has a ass load then no unless ur going to rebuild it if it has more then the motor you have now i would not pay 150
              is this with a trans as well
              try and get some history on the car it was in dont want to find things out when it is to late
                its from a friend and its got about 75k no i dont want the trans its automatic lol
                  150 isn't bad, but it's really not a performance upgrade. If you don't need a replacement engine, there are much better ways to make 145+ hp with your F22A.
                    yup its either that or try to get an h23 for now
                    cause my boy selling his h23 too
                      H23 is a much better option than the F22B1. MUCH better. At least if you want performance. If you just want an engine that will last and not kill you on gas, the F22B1 is fine. The amount of work to install them is about the same.
                      The F22A1 you have now is better than the F22B1 if it's in good shape. There's NEVER a good reason to remove a good F22A to replace it with an F22B1 or F22B2.
