2.0i header to 2.2i
    2.0i header to 2.2i
    So i was wondering if the header from -90 2.0i will fit to my -92 2.2i? It's from the EXi that has 130hp.
    It should fit. I believe all the F18/F20/F22 heads are pretty much the same casting.
      Ok. It's just hard to find some parts here cause the Accord i've got is from US. In my registration document says that i've got 147hp. Which is not correct, also i had ABS till the last inspection. Never had them in that car.
        to x2 deev, i bought a manifold and down pipe for a f22a6 and but i have a f20a8 fits fine
        UKDM 93 CB3 Page (1) H22A U2Q7 LSD
        UKDM 91 4ws Page (3) OEM Minter
        NOW H22A U2Q7 SWAPPED
          There was a Japanese model with nearly 150hp... However, the most any US CB got was 140. That was the 92-93 EX model, with the F22A6. There were no CBs badged as EXi here (or in Canada, to my knowledge). Are you sure you have a US-spec car?
          If it's a US model, with the F22A1 or F22A6 (being a 92, the F22A4 wasn't available... it was pretty much the same as the F22A1 anyway) then parts should be fairly easy to find. You'd just have to find a way to get them to Finland!
            Yeah, i'm sure. It's from California. My registration document is probably mixed with the other Accord's info, maybe computer has gathered that automatically. Cause, like you said the Japanese accord has got 150hp with the red or was it blue valve cover. Parts are quite easy to find, but the shipping is the real problem. You've got junkyards full of my stuff. But not many are keen on shipping internationally.
