wire tuck tips
    wire tuck tips
    okay am wanting to do a wire tuck and wanted to know if there are wire i need to extend and what gauge wire should i use
    thanks for the help
    starting on the drivers side
    and is it hard to remove the ac system
    well the easiest thing to do would get another wiring harness from another cb and do it that way by extending the wires.
    and the ac system is basically andything attached to the ac pump out just pull it off
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
      There is no set way to do it. Extend the wires that need to be extended, and hide them.
      Bucky's suggestion is a good one... use a spare harness for extra wire, that way you can use identical wire for extensions. You'll be sure to match the gauge that way, and you'll also retain the color and stripe of the original wire, so when you need to troubleshoot, you'll know which is which. Some people use black wire, and when there's a problem (there always is...) they're screwed!
