Signal Light problem, 4 way problem
    I have a strange situation 4 way lights don't work signal light does not work
    I can only hear noise from the flasher normal noise but no power at bulbs not even one.
    do You have any solution for that?
    I already replace signal light flasher nothing change still the same situation.
    is it front and back that dont work?
    try changing all the bulbs,the fuse in the kick panel under the driver side foot well.its all the way near the fire wall the only one on its own has a clear/white cover on it.
    if nothing then u have a short.
    my new turbo build
      You try replacing your hazard switch? No turn signals will work if your hazard switch is unplugged or broken...
      http://www.cb7tuner.com/vbb/showthre...=1#post1823428
      My Custom BB6 Dash Swap Thread
        I did not say on beginning that I hear my flasher relay clicking as soon as I turn ignition on without touching hazard switch or turn light switch ,but no power at signal bulb.
        its really strange .
        any idea?
          any suggestion?
            i agree with you, i have ran into this problem before and it was a bad hazard switch, the hazard switch overrides the turn sig switch.
