bad ground ???
    bad ground ???
    okay so i try and start my car and it does not like turn over and after i mess with the ground and then i try again it work and turns right over
    also were is a good place to get kit to relocate the battery to the trunk ???
    and wat r some things that will help with a trunk battery
    or wat should i expect will doing so
    I can't understand a word you're saying. Please type in English.
    What ground? There are a few different ones. If you are having issues, you shoulnd't be thinking about relocating your battery. Fix your problems first.
      My guess would be corrosion on the neg. battery terminal. If so, clean it.
      short
        Please type more clearly and reread your question before posting.
        I assume you are referring to the negative cable on the battery. If loose or corroded it can short and you will lose connection. Check entire cable, if frayed or damage you need to replace cable. If it is only corroded at the battery post you can clean battery post and cable connection with a wire brush and reattach.
        In regards to relocating the battery to the trunk. What is your motivation for doing this? It is normally done for weight distribution or safety in regards to racing. For a daily driver it is not necessary and could cause you more problems.
          it is cause am trying to get do a wire tuck a little down the road
          cause am wanting to boost it and will be cleaning it up and filling holes and what not
            voltage drop your cables while cranking. that will truely tell if you have good or bad connections.
              how would i go about doing that ??
                with a multimeter on Volts and both leads at opposite ends of the cable.
