Guys i need some help in doing this? Can someone tell me what is the procedure?
How to remove the rack and pinion off an LX?
undo the tire rod ends on both sides and you have about 4 bolts under the rack and pinion itself that has to undone. second you need to unsrew the fluid lines goin in to the rack and pinion itself. Finally you need to go inside the car under the dashboarad where the steering goes into the floor and you will see the swivel connecting steering to rack and pinion, undo the bottom and push it out and you have to maneuver it a little to get it out but thats the basic.
Good Luck
