If you see 4 black wires going into the back of the valve cover. Pull them out and the spark plugs are right down there. You need a special socket with rubber grippers to pull them out though.
Spark plug change
Originally posted by Tippey764 View PostIf you see 4 black wires going into the back of the valve cover. Pull them out and the spark plugs are right down there. You need a special socket with rubber grippers to pull them out though.90 ACCORD EX..<-- MR thread
Originally posted by xaaronx View Postor just a deep well socket and some needle nose plyers
Make sure to spring for the right tools. Dont cheap out. If you're already taking the initiative to do little stuff on your cb then you'll probably be trying to work on something else again later. So just build up a nice little tool collection. But stop into your local autoparts store. The people can usually tell you the tools you need for replacing your plug. And the holes are pretty deep. So make sure that you buy an extender for your socket otherwise you'll have to go back.
i believe the rubber boot part is to hold the porcelain part of the plug so it does not contact metal and crack it.
secondly, i bought a spark plug socket from autozone(like $7 wtf) and i bought 1 from my local 99 cent store. that one is actually better. the 1 from autozone the rubber part fell out after putting literally 2 plugs in it.
if you are unsure of the socket it should be a 5/8" spark plug socket. when you look inside will have a rubber boot in it.
i would suggest not using that spark plug socket until you have the spark plug screwed in and you know its not cross threaded before you torque it down.
you should be your 4 new spark pugs and some anti seize. LIGHTLY coat the threads of the new plug. here is a little trick if you did not already know this. i put the top (the white porcelain side) into a small hose that fits the top of the spark plug but not too tightly. this holds the plug securely as you lower it into the spark plug tube( where the plug goes inside the valve cover). i then thread the spark plug into its slot using the hose. if the hose slips as you turn it the spark plug it not going into the hole so know its cross threaded and needs to be put in again teh right way. the anti seize helps lubricate the plug threads and lets them slide in easier. the anti seize is a good idea. some people do not use it and will regret it if their plug ever does seize on the. most people also do not know you are supposed to torque your spark plug on cb7s to 13 ft/lbs
hope this helpsParts For Sale
BIG Thanks to HondaFan81 for all your help!!
Originally posted by wed3k View Postyou're not going to damage a spark plug by dropping it 2 inches.90 ACCORD EX..<-- MR thread
