I dropped a screw into the space in front of my A/C condenser, and then noticed there are a lot of leaves and gunk between the condenser and the radiator, so I want to make some room to get in there and clean the area up.
That requires moving the fans out of the way. No big deal, right? But the bolt holding the fan to the radiator is sitting just behind the front crossmember. I can't seem to reach it without taking apart my chassis. That doesn't seem right.
And now I notice the wingnut for the bleeder screw is under the crossmember. Wouldn't that also make radiator removal hard? Is it supposed to be like that? It looks like the radiator is mounted too far back. As if it were pushed back by a front-end impact long ago.
Does this look right to you?
