Air Intake Questions
    So I've been looking online/talking to mechanically inclined people I know about this and want to know what the consensus is here (or the varied opinions)
    The stock airbox '90 EX-R (A4).. is it better to just change its filter (to a Apexi/K&N/what have you) or go with a cone filter? If the cone filter is the case would it be better to fit it to the original rubber piping or to put in a new metallic pipe?
    Everything in this vehicle is OEM and I don't really plan to slap a huge turbo on or anything, just looking for some hp gains without too much hassle.
    filterwise..
    http://www.cb7tuner.com/vbb/showthread.php?t=56646
      go cone... you could buy a SRI but you could just put the filter on the end of your rubber tube and remove the air box... your not gonna "notice" gains from this but it does help some what
      MRT http://www.cb7tuner.com/vbb/showthread.php?t=188701
        Originally posted by casterX View Post
        I just wonder if that's even useful now.. It says it was exerted from a magazine in 1999.. shouldn't the filter technology used changed a lot by now?
        The air box has piping all down the side of engine bay, wouldn't that mean it would be more of a "cold" air intake than a cone that would be breathing alot closer to the engine? (Basically I'm wondering why the cone would be better lol)
          its simly about the way its designed as you mentioned the airbox has pipeing goin down that side of the car... that can stay... just take the actuall box and put the cone in its place this allows the air to flow up from that pipe the airbox was origanlly sucking from as well as the the rest of the air flowing in and out of the engine bay
            allright makes sense.. would you happen to know the size of the stock piping?
            basically i'm wondering if I should get this
            does cone size matter as long as a proper adapter is in place or does it benefit the engine more to have the proper (?) size?
              Filter technology hasn't improved. Filter size does not matter.
              Use a SRI/cone if you like the extra noise from the engine. Hold onto whatever you take out, in any case.
              Don't spend a lot.
                i would recommend just an sri with like a spectre or k&n cone filter. the k&n cone filter is a little more expensive than a spectre one but its a lot better. you could actually buy a whole sri system from k&n. it all depends on how much you're willing to spend. if you go cheap you'll get what you paid for.
                Frost White CB9: EX F22A6 Stock 5spd - Click Here
                  allright.. so I'm probably gonna go with an AEM SRI from what everyone has said/futher reading.. it will give me more hp at lower rpm then a CAI (granted not as much hp but w.e). Since I don't really plan on racing this auto anytime soon
                  thanks for the replies
                    As I said… if you're running stock, get the SRI for the noise it makes, because the horsepower gain will be nil.
                    A $20 unit will be just as good as the $80 one for you. Breathing isn't a bottleneck for our cars.
                      well i don't expect the hp gains to be very noticable.. mostly just wondering what the best intake would be for the DD car.
                        the only real difference is look but the best aftermarket air intake are the ones that are as far away from the hot air coming off the headers
