header wrap???
    header wrap???
    so whats the goods on a header wrap can someone let me know some stuff on this.
    i have dc header and just wondering bout a header wrap been seeing on alot of the cbs just dont know what for?
    Headerwrap helps keep heat in the exhaust system, thus helping the scavanging effect. It also helps lower under hood temperatures, which is a good thing if you have non-cold air intake.
      It CAN crack the tubing or welds of the header, though. Especially cheaper ones. By keeping the heat inside, it puts more strain on the metal.
        so do you think it would be a plus for me to get it or a negative?
        and to actually wrap the header would i have to remove it?
          what would be a good header wrap? what it's real name? otherwise any local store selling it?
          thx, kevin.
          1992 Accord EX-R Coupe [Mat Black] Sold
          1992 Accord EX-R Coupe [Rosewood]
            some say it rust or breaks down the metal fast. i have them on my cheap ebay header and it work perfectly. when you 1st put them on, you notice the acceleration is a little smoother. instead of the exhaust gases hitting the header pipping and going out, it allows them to flow down the tubing and out the exhaust where its supposed to go.
              Heat is energy, so the more heat that is kept in the exhaust stream, the more energy (and velocity) it should retain.
                well positive it is then haha i am planning on going to get some tommorow as a matter of fact! any specifics?
                  header wrap.... i removed mine it caused a crack in my headman header..to me it was a waste of money and time...but some swear by it ..
                    Header wraps trap moisture from condensation on the metal of your headers, there by causing premature failure. If you want lower temperatures get them coated and put your heat shield back on.
                      x2 http://www.jet-hot.com/headercoatings.html
                      1994 Honda Accord SiR Sports Sedan
                      “When I do good, I feel good; when I do bad, I feel bad, and that is my religion.” - Abraham Lincoln
                      CD5Tuner - A Fifth Generation Accord Community
                      PS3 tag: Mechtroop
