After thought about plugseal change.
    When torquing the rocker assembly, does it matter if the engine is cold or warm at least when torquing down the rocker assembly?
    You want the engine to be cold. Metal expands with heat, and you could damage the engine. Especially since our heads are aluminum, which is fairly fragile.
      id do it cold so you can check valve lash while you are in there. plus, most people are so slow at changing rocker arm seals that the motor will be cold anyways
        Well Im sure It wasn't hot when I did it but didn't know if maybe it was still a little bit too warm when I did it so that was my problem. Timing seems to be ok, but the idle is F*ed up still.
