alignment question
    alignment question
    ok, so im going to start off by saying this first
    if you dont know much about alignments then please try not to give me false ideas
    so i have my car lowered on tein springs
    i bought a camber kit that gives me 1.75" of positive camber
    i did my alignment today and my camber is still off by .5" (no biggie)
    and my toe on both front tires was 1.75 degrees negative (which was wearing the inner side of my tire badly)
    so i fixed the toe on both front tires and brought it within oem spec.
    as i did this i started thinking, if i put extra positive toe on both front tires will it even out with the negative camber that i still have and help my tires wear out a little more evenly?
    any info would help, thanks
    90 accord lx
    form > function
    Member's Ride Thread
    No, toe and camber are two different angles. You cannot correct one with the other.
      when you take a car to get an alignment, what do they correct exactly?
      I have the SPC adjustable ball joints. would they fix the negative camber for me or would i have to adjust that before i get it aligned?
      i have changed the upper and lower ball joints, inner and outer tie rods, the sway bar links and the rack and pinion.
      what would cause a tire to wear down excessively? the toe or camber?
      PSN: DJ-dlatino
      My ride
      http://www.cb7tuner.com/vbb/showthread.php?t=140370
        but positive toe causes the outer side of the tire to wear and negative camber causes the inner side of the tire to wear
        so i thought by adding these it would cancel each other out but i guess not
        90 accord lx
        form > function
          toe causes feathered wear to your tire which causes a lot more damage
          camber causes smooth wear which still causes damage but not as badly as toe
          90 accord lx
          form > function
