91 accord lx speedguage not working
    I have a 91 accord lx, the problem is that my speedometer is not working and the "S" light blinks, i jumped the ecu code and got a code #17 code which is the VSS, i have changed the VSS(i have extra ones that i have tried which i know work so i know its not the VSS), i also took out the instrument cluster and found that the circuit board had burn marks where the "S" light was and another spot on the circuit board so i replaced the circuit board,the speedometer gauge and the millage counter with used ones and my speedometer still will not work,the green S light stopped blinking but the speedometer still does not work(i have tried changing many different circuit boards and speed gauges in the cluster without success. any suggestions on my problem?
    Is the mechanical VSS asembly bolt tight??
    My vss assembly broke the bolt off and popped outta the trans..
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
      thanks for the reply, yes the bolts tight and i even made sure that the tranning was turning it to so i know it has nothing to do with the tranning either.
        could bw a harness problem, verify voltage a the VSS.
        _____________________________
        91 Accord F22B
