Recently the lights that display "doors ajar, trunk ajar and brake lamp" all flash on/off at the same time. Have you guys seen this before? How can I fix this?
dash lights going crazy, help!
I understand your problem. I had the same situation happen to me. I did several things to rectify the problem. Here is a thread that was generated about this topic:
http://www.cb7tuner.com/vbb/showthre...or+ajar+lights
Bottom Line:
There are diodes on the cluster's ckt board that are responsible for the door ajar, trunk, and brake lamp indicators. One of those diodes shorted out causing ALL indicators to illuminate. You can either:
1. find the shorted diode on the ckt board. This will require some good troubleshooting skills with a multimeter.
OR
2. get another cluster from the junk yards
I got another cluster from the J/Y and i havent seen that problem yet! One thing I did do was screwed the gas indicator up because I was doing the cluster L.E.D. DIY. I think I can fix that problem with another gas servo motor.
