93 Accord VSS
    93 Accord VSS
    When Im driving at normal speed limits my speedo is just reading 80mph unless im going faster than that... the tach works perfectly changing the VSS should fix it right? and thats located underneath the distributor cap on the transaxle right.. two wires coming from it...
    Yes, that is where the VSS is located. Check your connections first. If they're good, then replace the sensor.
    The VSS isn't associated with the tach, which is why that works fine.
      Thanks... Can I change it from the above the engine just like anyother thing or are there screws underneath that are out of sight? I searched Ebay but there are a few different styles...
        You can change it from the top. If you have a manual transmission, you may need to move some shifter cable brackets, and even disconnect the shifter cables for easier access. I'm not familiar with automatic, as I've never owned one, nor have I worked on this part on an automatic.
        Your best bet would be to get one directly from Honda, to ensure that it's correct and quality. www.hondaautomotiveparts.com usually has great prices and fast shipping.
