rear driver's side door won't open from outside!! help!!!
    Hey guys,
    Seems like my car these days needs A LOT of your guys' help.
    So the rear driver's side door....it opens from the inside, but doesn't open from the outside...is there a cable or a hook that is supposed to connect to the outer door handle?
    new $10 purple/yellow tint fog lights
    H22a Sleeper:
    http://www.cb7tuner.com/vbb/showthread.php?t=124470
    is there any resistance at all to the outside handle? if not you may have broken the catch on the handle inside the door. if you pull your door panel off you should be able to see the back of the handle and look for a pole or rod attached to it (or standing up near it, not connected to anything, if its broken off) that is supposed to be attached to the opening mechanism
      take the door panel off and make sure that the threaded rod is still connected from the handle to the latch assembly. There are several plastic retaining clips used in the whole handle/latch mechanism, make sure none of those have broken. They do get pretty brittle after nearly 20 years.
        Okay! Its kinda dark right now, so I'll have to check on it tomorrow in the daytime. But I'll check for a rod or pole.
        In response to Wolfamong...there is no resistance. So I think how wherm said, they get brittle after 20 years.
        H22a Sleeper:
          yeah its happened to me so it wouldnt surprise me
