3rd gear grind?
    3rd gear grind?
    Just one last post for now. All my other gears shift fine, its only the 3rd gear that grinds and it doesn't grind if I ease it in slowly. I'm okay with that for now since I plan on dding my cb7 so I can beat on my maxima or 4runner. The transmission isn't notchy because thats how my s2000 and 4runner felt so...
    Possibilities...
    - synchro?
    - clutch fork?
    Both don't sound like simple fixes and I am wearing about rebuilding or touching the transmission myself so any suggestions? Should I pay a visit to a shop? Look forward to hearing from you guys.
    Its a common problem arising from worn syncros.
    As the Syncro is worn, the shaft speeds can't match up as quickly resulting in the gears grinding before they mesh.
    Easiest fix is a 2nd hand trans. But if you did decide to fix it, just keep in mind syncros aren't cheap
    My 5.7 LS1 Holden Ute
      Yeah I read that too. 2nd hand transmission...should I hit up boneyard row? Theres like an entire street with 10-15 blocks of salvage yards here in Houston. The guy that sold it also mentioned the fluid hasn't been changed before...should I drain and fill with Honda MTF in the mean time?
        Originally posted by tv4184 View Post
        ... I plan on dding my cb7 so I can beat on my maxima or 4runner. The transmission isn't notchy because thats how my s2000 and 4runner felt so...
        So do you have a Maxima and 4Runner or a S2000 and 4Runner
        Rides:
        Accord
        92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
        96-AUDM-2.2 VTiS- Heather Mist
        CR-X
        88-JDM-Si- Black
        CR-X Del Sol
        92-JDM-SiR "Transtop" Motegi Edition - Silver
        95-JDM-SiR "Transtop" Daytona Edition - Silver
        92-JDM-SiR "Transtop" - Black
        Prelude
        91-JDM-Si-4ws "Si States" - Phoenix Red
        91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
        91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
        91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
          If you change the fluid to Honda MTF or GM Synchromesh (I've had luck with that), it may give you a little more time... but nothing short of a rebuild will actually fix it. A used trans is an option, but worn synchros are a common problem, so it's not guaranteed that you won't have the same problem.
          Keep it on topic, please.
            In my experience i used to have a really notchy 2nd gear. I have changed the fluid to Honda Manual Transmission fluid (not to say the original one was not Honda fluid) and it felt a bit better.
            I must add though that it felt better as time went by (not instantaneous), like after several hundred (or maybe because i dont realise it getting better till after it has significanly become better) many kms later.
            Then in the next service interval i changed it again (still using Honda fluids). It felt better again (once again only after driving it for sometime).
            So if you do change the fluids (and hope for the best) if it is to get better it will not happen overnight.
            Rides:
            Accord
            CR-X
            88-JDM-Si- Black
            CR-X Del Sol
            Prelude
              I hope it's not the original 10w30 fluid.
              There isn't a big difference between Honda MTF and GM Synchromesh right? Should I stay away from additives? Any idea how much a shop would be charging for a rebuild?
                Do not use motor oil.
                I know they say you can use it but i have seen it give that terrible honda 3rd gear noise everytime.
                There are conditioners in the honda fluid that i have seen remove that noise.
                I have personal had that noise in my b series and switched out the fluids and i havent had that noise or problem going on 2 yrs now.
                Might be a good inexpensive way to your fix
                  Never put additives in your transmission.
                  I've actually heard that people preferred the GM fluid over the Honda fluid. I've only run GM myself, and I'm pleased.. but I don't have any experience with the Honda stuff to compare. GM Synchromesh did help significantly with my 3rd and 5th grinds... granted, I was running gear oil (had a shop change the fluid, and they put that in there... I didn't realize until I dropped the trans to do my clutch!)
                    I wouldn't dream of using the 10w30 oil. I read the thread talking about when Honda MTF first came out and I think I'll pick some up today. Anybody know anything about adding Auto-RX to our transmissions? I used it in my previous cars in the engine to dissolve deposits before going full synthetic but I haven't decided if its worth the $22/bottle. Their description for use in the transmission says one treatment for the lifetime of the transmission helps get lubrication to parts that aren't getting properly lubricated.
                    To keep this thread on topic, go check my thread in the image gallery for the answer to the question JDMDriver posted.
                        the synchro itself is cheap but cracking open the transmission can be costly.
                          A few years ago, I had a similar problem with my 90 LX, the 2-3 shift was getting really tough. A shop opened it up (I pulled it) and wanted $1100 to rebuild. They claimed a big part of that was that Honda had updated 3rd gear so everything involved with that would have to be changed along with worn synchros and shifter forks. I told them to put it in a box. I wound up putting a used (supposedly 60K miles) in. It was supposedly from an Accord, but the right side mount studs had to be moved and the gear ratios are noticably shorter than the LX gears, so I think the tranny is from a Prelude. It is more fun around town, but a bit of a screamer on the highway. If you can verify a low mileage tranny, that is probably the better way to go.
