So i pulled the code after the CEL lit up on my CB and come to find out that its something in the fuel system. nOw the thing that i wanted to know is which component of the fuel system is the most like to fail to get the CEL to flash code ? would it be the fuel pump ? As always , thanks to eveyone whos post up
Check Engine Light CEL #43
o2 sensor. same problem here kinda.Accord SE
93se
Members Ride
Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
Sold to: sulimed, BurtonRiderT6, tishock
Originally posted by JoshM View Post
Originally posted by deevergote View PostBe sure to reset the ECU. It may still throw the code if you don't, even if the sensor is working properly.
i have known the way to clear codes without a scanner is to disconnect the battery for @ 5 minutes.
JENNA 91 LX
RIP 12-11-09 - 12/06/10
JANE 99 Infiniti i30
2-9-11 - current
"Life is simple, you make choices and you don't look back."
