Okay so here is how I stand with my accord. I have a 92 Accord EX. 176K miles. Everything but the head unit is stock. the only thing that has been replaced was the timing belt and water pump and brake pads when we bought it. I've had it about 6 or 7 months now.
Current problems.
1) There is a grinding/squeeling noise from the front end when i'm moving. If i tap the brakes it stops for about a second and then starts again. I know its definently in the front end and not a belt. We took off the tires and check brake pads but they are new so thats fine. He check the wheel bearings and said that they were fine but i'm not really sure about that.
2) My front and rear motor mounts are bad.
3) I'm leaking oil from my rear seal and oil pump. My dad says that i'm also leaking from the oil pan but idk. the whole bottom of my motor is covered in oil but when i check the oil (everyday before i drive it anywhere) I've only lost about a drop a day. nothing noticeable from the dipstick.
4) My exhaust from the cat to the tip needs to be replaced. We did a temp fix so i could get it inspected but that temp fix didn't last. now when the car is in any gear it rattles soooo loud :P
Other than that I don't think i'm missing anything. Just high-ish miles and those 4 problems.
Should I fix these problems or either get a CB5 or try to find a 6th gen civic (ah! dont hate me, i just really like the body style from the 6th gen.)
Thanks for any help guys
Current problems.
