recommended fuel pump?
    quite positive mine is taking a dump on me and i can't afford a brand new OEM one. any brand you guys would recommend that won't absolutely break the bank? links are cool too. thanks.
    90 ACCORD EX..<-- MR thread
    im using a HF fuel pump. 255 flow and apparently it flows more than a walbro. paid 70 shipped for it and they dont have much support for an accord so i had to figure out what pickup to use and i just reused the stock one. everything works well and i have about 1000 miles on it.
    http://highflowfuel.com/
      ^^ Thats not bad. You can prolly find Walbro's around that price too.
        I would go with quality over price any day as that is not a part that should be a shortcut! My Walbro 255LPH HP Fuel Pump – Part # GSS341-400-965 has yet to fail....
          PM sent
          Originally posted by HardInThePaint
          WTF, thats like placing the cheese underneath the beef patty and calling it a burgercheese. Regardless of how u slice it the shit is a cheeseburger.
            Walbro on ebay is $93 and thats the best price I've found on the Walbro. They are great fuel pumps, have used Walbro in a number of cars and never had a problem with one.
              i agree but i cannot afford $250+ for an oem fuel pump.
                Check your pm's
                  Before you decide to change your fuel pump make sure that your fuel filter is in good condition, injectors are cleaned or you might consider just changing the fuel pump mesh filter attached to it instead of the fuel pump>that cost about $10 and its sold any auto parts store. If that does not work then why don't you try going to a juck yard and taking it out of never been opened gas tank (what I mean is make sure the gas cap is still on the car and when your taking out the fuel pump make the screws were not already removed before) it should cost you about $20-I think I have one not sure if its for the accord I will look for it and if I find it you can have just pay the $5 shipping.
                  Good Luck
                    will a walbro 255lph be a direct drop-in if everything else (fuel wise) is stock? like, i won't need a tune or anything will i?
                      no u won't need a tune n there designed to be direct bolt on to the oem sending unit
                        it doesnt bolt onto the sending unit, the sending unit is on the other side of the tank.
                          The Walbro is a direct fit no modifications needed.It drops right into the factory pickup.
                          Also there is no tunin needed since the fuel preasure is regulated through the regulator and injectors, if anything you may get better throttle responce having that extra preasure goin into the regulator
                          http://www.cb7tuner.com/vbb/showthread.php?t=187851
                          sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
                          bought from:jokerxfn-tommi-'93cb7ex
                            Lucky you, I am on my third Walbro all original, never ran my car below quarter tank, or any thing bad they do fail, then again I am turbo charged.
                              Originally posted by A Zombies Minge View Post
                              Check your pm's
                              Are you PMing him in an attempt to sell a fuel pump?
                              if you have information to share, please share it publicly. If you are attempting to sell to someone in the Beginner Forums, then you will be banned permanently from this site. You will also get the guy you're trying to sell to banned as well.
