so here's what happened I'm driving down the street and switch to 2nd gear and press on the gas and it feels like its slipping, it just revs high and catches on slowly same happens with 3rd gear when i press the gas it just revs high. could it be i need to do a transmission flush and put new transmission fluid in? o don't think it has been changed for a looong time.
problem accelerating.
This topic is closed.
Originally posted by Nyne521 View Postyou said switch it to 2nd gear? are you driving a automatic or manual? cause you also said tranny fluid? sounding like an auto to me...
If it's a manual, it definitely sounds like a clutch issue. A fluid change won't help much there (though it's still smart to do... GM Synchromesh or Honda MTF).
If it's an automatic, then there are a few things that it could be. Fluid might help, but it's unlikely. Again, it won't hurt, though. Use Honda fluid ONLY. I don't recommend a flush. Just drain and fill.
Originally posted by deevergote View PostThen it's your clutch. Replace it.
Originally posted by wherm View Posthad to get towed...towing bill suck big time. I ended up just selling the car. It was a 91 Geo Metro that I had for several years. Great winter beater, but that was the last straw...
