today i saw a turbo at a shop that i was at today for 100 bucks and it had no shaft play but i just dont know what enige it came off of should i pick it up or no
little advice
With no shaft play it might be worth it if it was a decent fit for the car. I'd say go write down every identification character and number and bring it home and google. If its something with a t25 flange you could use a DSM exhaust manifold and build something real cheap. I have also seen T3 flange turbo setups, although I couldn't tell you where to get a manifold to support it. Basically you have to make sure the flow rate isn't to low for the 2.2. If its to large a turbo it will spool really late or never at all.
I almost went the route of a DSM setup but chickened out before i saw the project through.
Bottom line, don't buy it till you know what it is. Might be a cheapy Ebay turbo that is way over sized for the engine.
Originally posted by trickery View PostWith no shaft play it might be worth it if it was a decent fit for the car. I'd say go write down every identification character and number and bring it home and google. If its something with a t25 flange you could use a DSM exhaust manifold and build something real cheap. I have also seen T3 flange turbo setups, although I couldn't tell you where to get a manifold to support it. Basically you have to make sure the flow rate isn't to low for the 2.2. If its to large a turbo it will spool really late or never at all.
