I picked up a wrecked prelude that had a jdm h22a and m2a4 setup. Pulled it from the car the other day and found and interesting part inside the intake manifold and has me a little worried. The engine maxed out my 250psi compression tester, but since I found this part in the manifold i think i may pull the head to check things out.
So........
I've gone through a lot of threads and see that most people suggest using the Honda head gasket. Does anyone know if the usdm and the jdm h22a's use the same head gasket? I was going to try to call the dealer and see what they were running.
I will also be doing the typical stuff, water pump, manual tensioner, balance shaft belt, valve cover gasket, spark plug tubes, and what ever else I can think of. From what I see, those gaskets and seals are ok to get else where, local auto parts store?
Any suggestion would be greatly appreciated.
Thanks
Robert
So........
Thanks
Robert
