Originally posted by quickangel93
View Post
f22 engine s2000 trany
I can't believe nobody has mentioned the FACT that rotating the transmission in the wrong direction will cause numerous issues....
1. Extreme noise since the meshed gears are turning backwards.
2. High probability of explosion because the gears will act on each other with the opposite edge of the teeth which are not curved, not usually hardened, etc.
3. Instead of the gears pulling together when force is applied (another benefit of curved/meshed gears) they will push apart. When turbo force is applied the tranny case will crack, guaranteed.
4. The oil pump which lifts oil to the top of the tranny and pours over the internals providing lubrication to bearings and gears which don't touch the tub of oil in the bottom of the tranny will now turn backwards. It will suck air through the top and blow it into the sump at the bottom making the bearings run dry within minutes.
Good luck.
Oh yeah on edit:
The synchros will be useless also, they won't work turning in reverse.My Member's Ride Thread
Originally posted by 19dabeast85 View PostI can't believe nobody has mentioned the FACT that rotating the transmission in the wrong direction will cause numerous issues....
Good luck.
Oh yeah on edit:
The synchros will be useless also, they won't work turning in reverse.miss my turbo cb7
If your so stuck on building a RWD Accord I would suggest that you store it away somewhere for now. Get yourself a job and start saving up the money for all of the odd parts your going to have to buy. A diff that can handle 600whp in reverse will cost you more than you think. It would probably be easier to buy a complete drive train from a RWD Toyota or Nissan and make an adapter plate for the engine.
Are you looking to stay with an independent rear suspension or a fixed axle and suspension? That will also be an added cost factor depending on what diff setup you end up going with.Last edited by GhostAccord; 06-14-2010, 01:03 PM.
Originally posted by deevergote View PostHe wasn't planning on rotating the transmission the other way. He was planning on rotating the rear differential the other way.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
I'm pretty sure there is no way to use an S2k trans on an F22A* engine. A K series engine yes, that's been done.Last edited by GhostAccord; 06-14-2010, 03:51 PM. Reason: F22"A*" was added thought it was obvious that I was not talking about an S2K engine!
Originally posted by GhostAccord View PostI'm pretty sure there is no way to use an S2k trans on an F22 engine. A K series engine yes, that's been done.
I actually plan on making my accord RWD. Using S2k drivetrain. Right now im working on a 240sx project (sort of) to get a better understanding of how im gonna do it. Mostly because an S2k isn't exactly cheap. i wouldn't have even thought about the accord control arms not being able to handle any power if i hadn't. and thats with minimal wrench time.
the project will always seem easy in thought but will never be easy in execution. I just can't wait to get started.
Originally posted by Flatline View Postthe F20c has been mated to the k20 tranny before without much modification. if what you say is true, then wht you also say is false. weird how that works.
How is what I said false?
The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
k alot of questions lol damn but anyway... yes riotstarter its a take off the song riot by three days grace, good point about the tranny but like i said b4 i am still going threw everything, and its gonna stay cb based no other engine and i plan on using the sub frame from a 240 and just modding to fit.
and yes i relize this will not just be a bolt on and that there are alot of things involved, and the last answer for now is i have a job
To the OP: Find a tranny that turns the correct direction, the s2000 tranny will grenade in no less than a couple miles as well as create a horrendous noise much worse than operating a fwd tranny in reverse at high speeds.My Member's Ride Thread
Originally posted by 19dabeast85 View PostThink about it deev....the engine turns the opposite way thus the tranny input shaft is turning the wrong direction.......and all other tranny internals are turning backwards thus all the problems I mentioned.
Honestly, the best way to do this would be to use a full S2000 driveline. Forget about the F22A, unless you want something custom made for you... and like you said, the price is steep.
OR, find a transmission from another RWD vehicle with a motor that spins the same way as the F22A... if that exists. It'd be easier to mate that transmission to the F22A than it would be to modify an S2000 transmission to work.
