91 accord no start
    91 accord no start
    I was wondering if anyone could help me with this problem im havin?
    My car occasionally wont start on warm days. It will crank and crank just wont kick over. the main thing normally if i wait 1/2 an hour to an hour it will start. My battery, alternator, grounds, and as much wiring as i can think of are good. This is driving me nuts so any help would be very much appreciated. Thanks
    A very common thing to fail in the heat is the main relay.
    Listen to see if you can hear the fuel pump prime when you try to start the car. If you can't hear it, then the main relay is likely the culprit. Another way to check is to pull a spark plug, crank the car, and smell for fuel. No fuel smell, the main relay is likely not working.
    If you have fuel, then check for spark. No spark is commonly a result of a bad igniton coil or ignitor. Neither are very cheap new, but they are common things to fail after 20 years.
    Heat kills electrical components... so anything that was close to failing will often fail once it gets hot out.
      do you have a picture of the main relay by any chance so i know what part it is that im looking for?
        I could find one on Google... though you're just as capable of doing that yourself.
        It's under the dash, to the right of the steering column. If you have cruise control in your car, you'll need to move the cruise control computer to access the main relay.
          is there a way to tell if the relay needs to be replaced?
          also do you mean the efi main relay or the starter relay
