Electrical Problem (Cluster)
    Today i was driving and my gauges began to shut off. once i let off the gas all the way it began to read my speed/rpms again. once i got back on the gas they shut off again.
    My gas/temp gauge work all the time still.
    And another problem is i noticed since this started was i can turn on my windshield wipers full blast. But they still go really really slow.
    And my gauge light are way dimmer than they should be, i have them set on full but they look like there set only halfway.
    All these problems just began occur on my drive.
    Any help is very much appreciated,
    Bucky
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    no one know?
      have you checked all of your fuses and all of the wiring?
        Have you done any recent work on the car that may have triggered this problem or was it totally out of the blue? I would start by checking fuses and then wiring connections.
        I had a car come in with something similar and it turned out to be a ground wire that was loose in the engine bay. Took forever to diagnose.
          Check your grounding too. The small grounding prongs inside the engine bay, by the fender.
          MRT
            figured it out i had worked on the car and the alternator wire was not tightened all the way
