front end suspension noise
    Hey everyone my front end is really making these clunking noise everytime I drive over bumps fast or slow..I inspected the front end and my right upper control arm bushing is shot and my left lower control arm is shot also....I wanna know do they make bushing for these arms or do I hve to get the whole new arm and is a easy diy
    THANKS
    Sorry for the misspell...is it a easy DIY fix
      I believe you can replace the bushings, but it's difficult to remove and replace the rubber. Your best bet would be to replace the entire arm with an OEM Honda part. That would get you brand new ball joints as well, which is always a plus. If your ball joint boots aren't torn yet, they will be soon enough... and once a ball joint boot tears, it MUST be replaced, or you risk losing control of your car when it fails.
      Replacing the upper control arm is quite easy. 5 bolts and a cotter pin.
      Also, you can edit your own posts, rather than posting twice. Just use this button
      I just did it to add this bit.
        ohhh ok now I know and thanks for the reply back so fast
