plz help
    plz help
    iam trying to make my low bean turn off when i am using my high beam is that posible ?
    i have 8000k hids for my low but i have pink hids for my high but when i want to use my pink hids the low bean stays on is their a way to make the low bean turn off when high is on!?
    Not stock. You would have to re-wire but not the fuses I don't think. As it is stock, I'm pretty sure it has separate fuses, but for whatever reason, the highbeam switch simply turns the high beams ON, not the low beams OFF.
    Hope this gets you started in the right direction! If you need any suggestions on how to re-wire it, lemme kno. That's one I'll have to think more about haha
    Please learn to type!!
    CHECK IT! My ride thread...
    http://www.myspace.com/stephenwaltonphotography
    You'll need to spend real money on parts with real engineering to see any real gains. Anyone who says otherwise is either ignorant, or trying to sell you something.
      well all i want is my lows to turn off when i activate my highs thats all any suggestions!
        Meaning you would have to redo the switch and wires yourself, or have a buddy work on them. If you need suggestions on what to do for it, I bet there is a DIY thread on this, seems like a pretty popular idea.
          how will i find a diy iam a nubish here lol
            Cheap/easy way would wire a toggle switch to the low beam wires. That way you can still have the lows on with the highs for visibility, but flip the switch to turn them off at car shows, meets, etc... which is why I'm assuming you got pink high beams.
              is their a diy on this!
                Just drive around and hold it on. Like when u flash but hold it instead. Thats super wack but IDK how else u would be able to do it.
                  Just wire in a relay to the lowbeam circuit so that the switch part of the relay cuts the power to the lowbeams. Hook the relay coil wires up to the highbeams circuit. When the highbeams go on, the relay switches and cuts power to the lowbeams (you will need a relay that has 5 terminals, or one that can open the circuit when activated). Instead of using a relay to turn something on, your using a relay to turn something off.
                  ON_N20
                  Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
