car boggs when turning
    hi guys! i have a 93 accord ex 5-spd. my car has been bogging down while turning. this just happened sunday. i would take off from a stop. come to a corner and make the turn. the car would start bogging in the middle of the turn or sometimes after the turn. the bogging can last up to 5-6 seconds (5-6 being the longest) i cant really give any specifics because its happened a handful of times. totally random. when i say the car boggs i mean the car moves back and forward like as if you had a bad launch. this happens under normal city driving rpms under 4k rpm. i think i may have a bad p.s pump because sometimes at a stop or at low speed when i try to turn i can hear it. not a squeal but metal on metal type sound
    sorry if my description isnt bringing up any ideas. ask as many questions as you like.
    thanks
    -steve
    This may be a silly question, but are you running low on gas in the tank when it occurs?
      nope it was a full tank
        Either your power steering pump is causing more load on engine or your base idle is not properly set.
        To eliminate P/S pump out of equation, remove the P/S belt. Run engine for a couple days and if no engine bog, then you know it was pump. Otherwise consider the below.
        If your engine bogs (engine RPM go down temporarily, slowly recooperates) when headlights, A/C and/or rear defrost are on, then it is improperly set base idle.
        Reference DIY sticky for setting base idle.
          clean iacv first and then set base idle. if that doesnt work, check your power steering rpessure switch.
            Sounds like a power steering pump problem to me..
