s0 i was w0nderin is there such thing 0r d0 u have t0 rem0ve a layer fr0m the st0ck head gasket?
thiner head gasket?
I've been told the middle layer.
Why not go with cometic headgasket more fullproof without worrying about the gasket blowing they different thickness headgaskets.Last edited by Darkcloud; 05-24-2010, 11:53 AM.
Originally posted by 92smokeaccord View Posts0 i was w0nderin is there such thing 0r d0 u have t0 rem0ve a layer fr0m the st0ck head gasket?
If you remove a layer from a stock MLS headgasket it will ruin the gasket and it will leak. It between each layer there are little lips i guess you could say and when the gasket is compressed they lock together.Originally posted by 92jdmif you have any mechanical inclination, it should be easier than a drunk highschool girl after prom.
Why not go with cometic headgasket more fullproof without worrying about the gasket blowing they different thickness headgaskets.Originally posted by 92jdmif you have any mechanical inclination, it should be easier than a drunk highschool girl after prom.
A thinner head gasket is an oldschool way of raising compression (and thicker to lower it). Honestly, you're better off doing it the right way, with higher compression pistons, and using an OEM gasket.
But hey, lookee here... I searched the common F22A performance parts providers, and guess what... they have what you're looking for!
http://www.f22parts.com/item_copperheadgsk.htm
http://bisimoto.net/store/index.php?...Path=3_116_121
Shocking, I know...
Originally posted by deevergote View PostA thinner head gasket is an oldschool way of raising compression (and thicker to lower it). Honestly, you're better off doing it the right way, with higher compression pistons, and using an OEM gasket.
Shocking, I know...
your probably going to end up with issues when using anything other than OEM gaskets. If you want to raise your compression do it the right way by getting pistons and rods. The 5hp or so you gain by removing a layer or getting a thinner crappier than stock gasket is not worth the effort of ripping the head off just to replace a gasket.
member ride thread
DIVULGE MOTORSPORTS
yeah I would do it the right way...My friend did this and it was messed up from the time he done it until he done it the right way....But I know for sure ebay has what your looking for.And i belive its f22parts....But maybe my friend did somthing wrong bro...I don't know just try'n to help out......If you get it done tell us whats up......But for real think about it....Only give advice when I know or have done it and it worked
Originally posted by 92smokeaccord View Posti saw the bisi gasket but is it a st0ck replacement?i cant find the inf0 0n it.even th0ugh is says m0re inf0.....
It will fit directly, yes. The thickness varies, as shown by the site.
