i installed a intake for awhile now and it makes this whistling noise when i step on the gas..does anyone know what it is and how to get rid of it?
intake whistling noise
Originally posted by kenjin View Posti installed a intake for awhile now and it makes this whistling noise when i step on the gas..does anyone know what it is and how to get rid of it?
not sure how to reduce the noise except convert back to airbox lol
i have a h23 plenum. my idle screw is all the way in. my idle is fine.
and i noticed that at 3k-3500 it whistles.**Blk Housed Slut Crew Member #1**
Originally posted by ExplodingCake View PostHow noisy is noisy? I have an intake on my Civic and it whistles like it has a turbo on it.
Got a buddy with a different filter? Try swapping him and see if it helps. THe whistling is caused by air being sucked into the engine at a relatively high velocity. At somepoint in your intake system, something is causing the flow to be disturbed in such a way as to make it whistle. It could be something you're stuck with (such as the flow of air crossing the vacuum ports in the tubing (like blowing across the top of a bottle)) or something you can change (like a poorly designed filter.)
