where can you motor size?
    Ok here's what's up I have a 92 accord ex I always thought that it had an f22a1 motor but I went to the part store and they said it was a f22a6 so yeah idk where it would tell you this can any one plz het and thanks
    right were the tranny meets the block on the front side.
    http://www.cb7tuner.com/vbb/showthre...=1#post1823428
    My Custom BB6 Dash Swap Thread
      x2
        Originally posted by southsidecb7z View Post
        x2
        Care to add anything that's actually helpful?
          uh-ohhhh....
          deev is taking aim....
          OP: right near the little rubber plug where you check your timing, you will find the engine type stamped into the block. pretty hard to miss....
            Its actually pretty easy to miss if your engine has alot of corrosion on it.
            Look really close OP if its dirty. A letter or 2 might appear. Or you might need a wire brush.
              The parts store guy just gained you 10hp.
                how'd i do that?
                i keed.
                always a pleasant surprise to find a sweeter engine than suspected underhood.
                unless of course you drive the car that i just smashed with my H.
                  honestly anything you order is pretty much the same except for one intake gasket. ive ordered head gasket sets where they just give you both which is nice for extras.
