Like the whole car to shake it was not doing this before I installed it to check one side when I had installed the other side it started to shake the car when I put t in gear I was wondering could a bad axle cause this?
Would a bad axle cause....
if you're stationary, then its your motor mounts. But I don't quite understand what you're saying
When you're in motion it could also be wheel balance.
member's ride thread
91 Accord SE 176k
Ok this is what happened my axle came apart I bought a new boot for it put it on and it's almost like when I installed it seemed to be strechin like it was short an with the car in the air still I put the car In first and it's like at first it did not wanna move so I loosened the axle nut and then it started to move but shook the car
Are you saying that the axle itself came apart or the boot? If the axle itself came apart I would not recommend putting it back together yourself. I would buy a new or refurbished one. And lastly I would definitely not loosen the axle nut they are supposed to be tightened down to 180 foot pounds I believe. Loosening it would be dangerous to drive on.[/url]
Originally posted by 1lov3mycb7 View PostOk this is what happened my axle came apart I bought a new boot for it put it on and it's almost like when I installed it seemed to be strechin like it was short an with the car in the air still I put the car In first and it's like at first it did not wanna move so I loosened the axle nut and then it started to move but shook the carGary A.K.A. Carter
[sig killed by photobucket]
