91 Accord LX blown oil seal
    So, I was going down the highway today doing about 60, when my oil seal blew. I have an f22b2 swap (not my call. It was done by a previous owner), and was wondering if that may have anything to do with it, as it was not swapped properly. Any help would be great.
    Kind of vague......you think the previous owner didn't swap it in properly causing the seal to blow? Also which seal? I'm gonna take a wild guess and say balanceshaft seal as that's about the only one I've seen blow out.
    If it is the balanceshaft seal, and it didn't have a seal retainer, it was just old. They tend to pop out over time. Honda started using a retainer if it was brought into a dealer for a timing belt change as it was becoming a problem as the cars got older. You can get them for $5 or something from Honda.
      The balance shaft seal and the rear main seal are the two that can "blow", causing pretty catastrophic failure. If you didn't stop the engine right away when it happened, irreversible damage may have been done.
      Aside from the previous owner's failure to replace (or at least properly replace) these seals at the time of the swap, there's really little chance that he would be at fault for the failure. There's not much you can do when swapping an engine to compromise a seal like that.
      They just get old. The F22B2 was used in 5th gen Accords from 94-97, so you're looking at 13 year old seals at least. They can fail over time. They WILL fail over time.
        Thanks Fellas. What happened was, it started spraying oil out of the back of the engine (towards the firewall) When I came up to a stop light. I, unfortunately, had to tow it home just now. Rather depressing, to be honest. >.< One of my buddies had the exact same thing happen to his CB7, and it cost him a grand to fix, so I'm not entirely sure EXACTLY what happened. He just said it was an oil seal.
          See if you can figure out the exact location of the seal. You can find some pretty good parts diagrams with part names on www.hondaautomotiveparts.com.
          It won't be very expensive to fix if you killed the engine before it ran dry. If it's just a matter of replacing whatever seal failed, it'll be something you can do yourself. If it requires a full rebuild... just yank that crap engine and replace it with something better (F22A, H22A, etc...)
            I'm pretty sure it's my Main Seal. And, I managed to blow my valve cover gasket in the process. I'm also pretty sure my engine ran dry because of the fact that I had to drive a little ways, and wait at a rather long stoplight.
              The transmisson is covering the rear main seal. If that went, your oil would be coming from where the transmission housing and the block meet.
              If you ran it dry, don't even bother replacing the seal. Just replace the engine. You'll put a lot of work in for nothing if the internals have been damaged.
                Thanks for the help guys. I'm sure the internals are shot, and I found a freshly rebuilt F22A1 for $500, so I'm most likely just gonna snag that and drop it in.
                  f22aX FTW =D hope everything works out for ya
                    Thanks! again, I appreciate all the help! I should be getting a new engine in the next few weeks.
