Sooooo. I bought a CB7. And it needs a water pump changed. I did all that was necessary up until I encountered the crankshaft pulley. I tried to remove it. I have SEVERAL words describing how I feel after failing numerous times. If I said them all, you'd all be desensitized for life. No recovery guaranteed.
That being said here's my problem.
I can't get the bolt to budge.
I have tried an electric impact (rated at 230lb's of torque) and no luck. I was really hoping it would've worked since I don't own an air compressor or an impact wrench.
I let a friend of mine try and it become a wet mess of PB Blaster everywhere.
I even tried torching it with a MAPP gas torch and torquing it out! No luck. I checked the diy section found the timing belt change video and the guy was using a flipping acetylene torch!
What am I to do? Should I rent a high powered air compressor and borrow an impact, or should I find an acetylene torch thing?
I went to the parts stores nearby and they didn't have a pulley removal kit.
I don't want to break the budget, everything I've tried so far has been well under what it would cost to have the water pump changed.
Should I just get it changed at a shop? It currently can't run. Gah.
idk what to do.
Or do you guys have any tips?
idk what to do.
