Does anyone else have these on their stock EX rims? I tried searching but could'nt find what I was lookin' for...was wondering if they would fit OK? Thanx...
Will 205/65/15 tires work?
well if you already have them, they WILL work, they'll just be a bit meaty.90 ACCORD EX..<-- MR thread
I have these wheels but havent tried them on yet.
I bought them with Honda Rims (unique pattern too) but i then changed my mind as i wanted the original jdm saw blades look for now.
I set them next to it and it seems to fit ok in the wheel well.
Remember some of the european cars have tyres which have close to only half an inch from the top of the wheel well and they still have enough play to avoid rubbing.
I think a big factor on your accord being able to accept this tyre are below
1) The OFFSET on your rims (particularly if aftermarket or from another make and model even if still Honda rims).
2) Another is the camber. If the setting is too acute there will be less play for road bumps.
3) One last factor to consider is your suspensions (shock and springs). Extra travel caused by worn suspensions may cause the tyres to rub. I didnt mention ride height since you confirmed your car is not lowered.
If all the above is stock then chances are you should be fine.
One big or HUGE advantage of selecting tyre's with this dimension is you get more tread life and comfort. Perfect for someone on a budget or cruiser and classy build approach!
It would mean more money can go towards JDM and other rare parts since you will not be needing another set of tyres for a longer period (compared to someone with low profile tyres with low tread wear ratings, softer rubber compounds that wear out faster and costs more).
Personally I would concentrate more on maintenance and JDM parts rather than blowing money on low and expensive profile tyres.Last edited by JDMDriver; 05-17-2010, 10:13 AM.Rides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
