a/c problem
    a/c problem
    My a/c has been working fine I had it on this morning with no problems. My cooling fan wasn't working so i tracked that down to a fuse. changed the fuse now the a/c isn't working. the a/c light doesn't come on and the clutch isn't engaging, the a/c clutch fuse is good also. What else can i check or do?? thanks
    Mack
    Was it exactly same amp fuse that you replaced on a/c and cooling fan? If it stopped working when you changed the fuse for cooling fan you could test the a/c fuse with voltmeter. Usually you can see that fuse is bad but i've seen that broken fuse can sometimes look just like new one. So if you don't have voltmeter then you could try another fuse.
      I know this is something simple that i'm overlooking
      - put in 20 amp fuse for engine cooling fan
      - swapped and checked 7.5 amp fuses for a/c clutch
      - swapped and checked two relays behind left front headlight
      - checked power coming in to relay
      - checked continuity of wire going from relay to clutch
      - hooked 12v directly to clutch and it clicks on
      - interior a/c light also doesn't come on now either
      - also have power going to the 7.5 amp fuse under the dash
      The a/c was blowing cold 5 minutes before i put that 20 amp fuse in for the engine fan. thanks for the help
      Mack
        It seems to be a fuse problem cause the light should come on even if the a/c isn't work or the coolant is low. I would check the from the main fusebox these things: heater blower relay 30Amp, AC condenser blower motor relay 15Amp, engine coolant blower motor relay 15amp. Those are amps that i have. Then you could check from inside fusebox these: engine coolant blower motor timer relay 15Amp, AC master switch 7,5amps, AC-heater airmix flap motor 7,5amp. Check those and let me know if still not progress.
        Oh yeah, does your heater blower work now?
          yea the heater and blower motor work i'll go check the rest. thanks
          Mack
            everythings checked ok with the meter
            Mack
              not sure if you've done this but maybe reset the system by disconnecting the battery for a few minutes... just a suggestion.
              Originally posted by Quashish
              Holy crap thats a clean F series. jellish mang.
              Quashish dictionary
              Jellish: (adjective) Jel-%i'sh+#
              To envy something to point of almost blowing a load involuntarily.
                great idea but it didn't work so now i also have to reset my clocks and radio stations too, thanks a lot
                mack
                  If your fuses are ok then i can't figure out anything else than the blower unit itself. At least thats what i would check it out but there could be a lot of other reasons. I would have bet that's a fuse. Might be a dumb question but did you have the car running while changing the fuse? And i would still recheck ALL (not just the ones i mentioned) the fuses cause it has happened to me that i've missed one or it has been a fuse that doesn't directly affect on a/c. Sounds like repeating but sometimes it helps.
                    I tore the dash apart and jumped the a/c switch out and the light and the condensor fan came on so I think that might be my problem. Any idea where I could pick one of those up at? thanks
                    mack
                      So it was the blower unit, right? Well you can get one from ebay for example. http://cgi.ebay.com/ebaymotors/1990-...Q5fAccessories
                      Also you can check the blower unit if there is someway to fix it. Could also be that the circuit has damaged so there's noway to repair it. Would buy one from ebay, they don't tend to cost much. Of course you can buy new one but it'll cost a lot more and don't see reasons why not buy a used one if in good condition. Hope that it'll work.
                        I wasn't thinking of that as the blower unit but yea i believe that's what is bad. it would be nice if i could just solder in a toggle switch just to jump that one circuit out. just don't know if the switch would handle the current. thanks a lot for your help and the ebay link.
                        mack
