how do u check the V-tec solenoid to see if its good or bad ?
v tec question
check it like any other solenoid make sure the resistance is withing OEM specs and that it energizes when you give it power to the correct lead
Originally posted by deevergoteHe's disappointed in my bulge... it doesn't even come close to being as impressive as his.
1996 Civic hatch *gone*
1994 Integra
Originally posted by '93CB7Ex View Postyou need to change the VTEC fluid..
to check your wiring.
check continuity (consistancy between 1 side of the wire and the other side)
if you do not know how to do this, please speak up.
-from ECU A4 (VTEC solenoid, if wired correctly) to the solenoid (1 wire)
-from ECU D6 (vtec oil press, if wired correctly) to one of the press switch wires. the other is a ground.
hopefully that helps.
here is a pic of what is what..
