as the title says the car is hard to start when the car gets hot i have already change the starter and battery also i recently did a battery relocate.but when the car cools down abit it start up like nothing
hard to start when car gets hot
It may be the main relay. When it's having trouble starting, listen for the fuel pump. You should hear it prime. If not, the main relay is the problem.
It could also be a bad ignition coil, bad ignitor, or dirty, loose, or damaged battery cables or grounds.
Determine if your no-start is a result of no spark or no fuel... it will narrow things down considerably.
