hey guys i just got a 1990 ex coupe 5 spd with 189k for 500 bucks...Any ways i was driving it home after doing the timing belt water pump seals etc. and i noticed its hard to put the car into gear...like till it warms up...i know i need to do the clutch but can it be low on tranny fluid??
Hard to shift into gears
Originally posted by cb7_ex_coupe View Posthey guys i just got a 1990 ex coupe 5 spd with 189k for 500 bucks...Any ways i was driving it home after doing the timing belt water pump seals etc. and i noticed its hard to put the car into gear...like till it warms up...i know i need to do the clutch but can it be low on tranny fluid??I know that you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant.
theres also the issue of a leaking or bad master/slave clutch cylinder. Im havin this issue with my car now. My master cylinder has a small leak in it. Enough to when i pushed the clutch it would not fully disengage. Till i replace it, i adjusted the rod on the pedal out more. The more travel gives me more pressure in the line and just enough to fully disengage the clutch. Shifts great for now. Just the pedal travel is really annoying lol.
Originally posted by deevergote View PostBleed the lines properly, replace the transmission fluid with either GM Synchromesh, or Honda MTF. Nothing else. Make sure you don't have a short shifter installed, as that can cause notchy shifting as well.
