i just got a honda accord and the engine block code just has a HA.. its a sohc but thats all i know.. anyone ever heard of this motor
Block Code HA
Where is the block code that you are reading located? That's not a Honda block code, so either you're looking in the wrong place, or you have something really weird.
The stamp should be to the left of the exhaust manifold, on a flat square section of the block.
Where are YOU located? In the US, the only SOHC engines, the ONLY engines, that came stock in the 1990-1993 Accord were the 2.2L F22A (F22A1, 4, and 6 to be precise)
Other countries had 1.8L, 2.0L, and 2.2L. There was a 150hp DOHC 2.0L available in some areas. Some areas had carburetted engines (I believe all the 1.8L were carb, and some of the larger ones)
There's no need to double post, the whole site is tied together, someone will see your question. http://www.cb7tuner.com/vbb/showthread.php?t=159882
And I think you're looking too high for the stamp:
(stolen from H-T. Belongs to GhostAccord's Photobucket.
Originally posted by visualpoet View PostThere's no need to double post, the whole site is tied together, someone will see your question. http://www.cb7tuner.com/vbb/showthread.php?t=159882
