Distributor Interchangeability ?
    Just need to know if it is true that from 92-95 Accord distributor is interchangable ? Also is coil the same ? I was at junkyard and 94 Accord distributor looks identical. Also found this one on ebay that says 92-95....
    http://cgi.ebay.com/ebaymotors/honda...#ht_562wt_1165
    Originally posted by HardInThePaint
    WTF, thats like placing the cheese underneath the beef patty and calling it a burgercheese. Regardless of how u slice it the shit is a cheeseburger.
    as long as they are both internal or both external then they are the same.
      Bump for info.
      Im assumin cd5 ext coils r interchangable to cb that has ext coil setup?
        I have fixed it. I had a bad wire on the 2 pin connector, it broke coming from the distributor where it meets the clip. I just used a quick splice and a couple quick connects and jumped past the clip to where the wire came out on other side and connected it to the distributor. Go $2 fix!!!!
