At what rpm will the v tec kick in, because i just installed a h22a and im not feeling the v tec kick on, (the car doesnt seem like it running to its fullest)
v tec wont kick in
Don't worry about a P28. This guy is giving lousy information on something that he clearly knows nothing about. You're nowhere near needing a P28 yet... and if it won't run correctly on a P13, it won't run correctly on a P28.
Your CEL is on, which means there's a problem. Pull the code, and find out what it is. Your ECU is in limp mode, which means VTEC will not engage. It also means that pushing your car to those limits could seriously damage the engine. Find out what that trouble code is, and fix it... until then, don't drive the car.
