Not starting
    Not starting
    Alright this dosent apply to my car but a 1991 ex sedan i found on craigslist for $500
    I checked out the car today and its pretty nice actually but...
    When you get in and turn the key nothing happens. All the lights go out ( like they normally do ) but the starter dosent turn over. It acts exactly like im not pushing in the clutch.
    The guy says one day he brought it home and it just didnt start up. Then a few weeks later it started right up and was perfectly fine. Then a few days later it wouldnt start again.
    The car is a 5 speed by the way.
    hows the battery
      Originally posted by illestatus View Post
      hows the battery
      It was really new. June 2009. Nearly a year old but pretty new. I tested out all the elctronics in the car and they worked pretty good. The car didnt struggle to operate anything.
      PS: Why did you change your name?
        Try tapping on the starter.
          Check the clutch switch and starter.
          Also check if the starter solenoid is getting its 12V feed when in the start position.
          My 5.7 LS1 Holden Ute
            im gonna go with red on this. Try tapping the starter or just bringin another one to test it with. Had this issue on a integra. Sometimes if you knock it around a bit, it will fire up.
              Does it click, and lose all electrical power? Or do you just turn the key, and everything else is normal, aside from nothing happening with the starter?
                even a faulty starter will click or make some sort of noise. (same with a low battery)
                if the entire car is silent, id lean towards a park neutral, clutch switch, ignition switch or starter solenoid.
                I <3 G60.
                  Do you know when you try to start a manual without the clutch pushed in? Or an automatic when its in anything but P or N? it acts like that. Everything is normal but there is no starter activity.
                  Im going to try what red said. I have seen that first hand actually on a 99 accord 5 speed with an f23a1. When you hit the starter with the key held down you could hear it grind around in there.
                    just try to bump start it??...
