louder after valve adjustment attempt
This topic is closed.
    alright so i just did my valve adjustment and it sounds louder now. i did read on here that its suppose to for a little while, something to do with the the engine having to get used to it again, but i was wondering how long is a little while? It did quiet down a little when it got warm, but still sounds louder than normal.
    I dont think its suppose to be louder, should run quieter and smoother after...
      When I did mine it was quite. What specs did you go by
      NEW CB
      old Darkcloud : 1990 Accord EX MRT
      new
      DARKCLOUD : 90 ACCORD EX MRT
        0.10 intake 0.12 exuast
          here is the link: http://www.cb7tuner.com/vbb/showthre...lve+adjustment
          scroll down a little and thats where i saw it
            Important missing information... inches or mm???
              there oem feeler guages from auto zone, i think there mm tho. i gotta check
                yea mm
                  there's your problem.
                    .10 mm is .004"
                      wait lemme post pics 2 show u wat my feeler guage looks like
                        scratch that cuz it wont come out clear, but it shows:
                        .010 .012
                        .254 .305
                        mm mm
                        jus like dat
                          .010 .012
                          .254 .305
                          mm mm jus like dat
                          Good, you're fine. You probably just messed up somewhere.
                            one question: the guy in that honda video says that he turns the cam until the cam lobes are down and at the base, but when i follow the haynes manual and line up the flywheel tdc i noticed my cams are not at the base on cylinder #1. Is it possible my timing is off and thats wat causes my adjustments to be off?
                              You're probably just not looking at the right stuff. When the arrow points up, adjust cyl 1 which is farthest away from the dizzy. Also just a tip, when you're switching between intake and exhaust it is easy to accidentally have 2 of the feeler gauges stuck together. This will definitely screw you up and is very easy to do.
                              Edit: and I'm talking about the arrow on the inside of the cam gear. Don't use the flywheel for your reff point, the cam gear should be your compass for this job.
