where can i get a short shifter for my car?
where can i get a??
Neuspeed makes an adapter.
P-Spec used to make a full shifter, and you can find them used.
Forbidden makes Prelude shifters that can be modified to work.
You can spend $3 at Home Depot to make a bracket that will do the exact same thing as the expensive shifters.
However, a short shifter will usually cause premature wear to your transmission, and cause very notchy shifting, with a greater potential for grinding gears.
